temperature range -- automotive
Posted: Thu Oct 25, 2012 6:11 pm
>Is it tough enough to withstand this environment? Would
> there have to be any special considerations in regards to mounting
> (vibration suppressing) or cooling?
The ARMexpress is rated -40 to 85C so temperature should not be a
problem. While 12V is allowed as an input power, that would be a lot
of power for the regulators to throw away, so some pre-regulation
would be best.
Vibration would be fine for the ARMexpress, but the concern would be
if a socket is used. Some way to hold the ARMexpress in the socket
would be needed, or it could be soldered directly into the motherboard.
would be best.
