multiple SPI
Posted: Thu Oct 25, 2012 6:17 pm
>On the topic of SPI, how many
>groups of 3 pins can be used at one time as SPI Ports, or is there
>only one dedicated SPI port on the ArmExpress or ArmMite? any
>advantage of multiple SPI ports versus one SPI port, with multiple
>Chip selects, to enable 3 or 4 SPI devices
SPI can be done any any set of 3 pins (assuming a CS)
Best would be to use the same 2 pins for CLK and DATA and then seperate
pins for CS for each device (thats how the ARMweb does it). This would
allow quite a few devices. If you find you need more parts or to chew
up less pins, a 74HCT138 to turn 3 lines into 8.
