10 mv per degree Kelvin (very linear).
At room temperature, they put out about 3 volts, But can go up to
around 4V with added heat. (Using a 3.7K pull-up to 5V).
(For my project, I would like to monitor a -20 F to +230 F temperature range).
So, to make the sensors work with a 3.3V ArmMite, I've used two 4.7K resistors
to divide my 3 volts in half. I'm seeing about 1.5V on the analog inputs.
Anyways, converting Kelvin to Fahrenheit in Coridium basic might
be too big a task for me, since I was spoiled as a child by floating point.
I wonder if there is any sample code around for this kind of task?
Thanks for any comments..
Cheers,
Rich
