Big Current Source
Posted: Thu Jan 17, 2013 2:02 am
>from the Yahoo Forum
>looking for a 1A controlled current source
A current source can be built with a DAC and a resistor divider in your case to get a 0 to 0.1 V reference, an op amp for feedback with a big MOSFET with a low resistance and small current sense resistor (remember it's dissipating a lot of heat)
Values are not exact, but the general idea
- BIGcurrentSRC.gif (9.06 KiB) Viewed 35197 times
Re: Big Current Source
Posted: Thu Jan 17, 2013 2:43 am
by danlee58
I was thinking along those lines. I'll ned an Op Amp that works on a single supply, and a way to mount & heat sink the FET, also a DIP or SIP DAC.
I got my ARMmite board working. I cleaned the solder splashes and flux. I plan to use it to test my Interrupt Proceedure, but I'll do the job on the Pro board. I have changes to make to the circuitry on the ARMmite board, and I don't think it will survive removing more components. Unlike software, you can't simply download new circuitry.
Posted: Thu Jan 17, 2013 1:02 pm
by danlee58
I'm looking at a Maxim MAX517ACPA DAC, and an NXP BUK75144-55A,127 for the MOSFET. I need through hole mounting for the DAC. I still need to identify a single supply Op Amp.
Posted: Thu Jan 17, 2013 1:50 pm
Even if you don't buy from them Digikey, they have the BEST searchable site for electronic parts.
I entered op amp, and it gave me a long list of categories, scrolled down to integrated circuits, op amps...
Still lots to choose from, but then selected thru hole mounting and 1-5 V single supply.
And it returned
Digi-Key Part Number NJU7014D-ND
Price Break Unit Price Extended Price
1 0.78000 0.78
25 0.58520 14.63
100 0.48750 48.75
500 0.46800 234.00
Posted: Thu Jan 17, 2013 9:03 pm
by danlee58
The parts that I selected are from Mouser. I'll try Digikey next. I have purchased from both in the past. I will look for another DAC, because the Mouser unit is a Dual and priced at $3.73 ea for 1 to 25 units.
In the Dual DAC setup each DAC uses a seperate External Reference, since there are two DACs in a package, I could use VCC as a reference for one, then connect the 1st output to the Reference of the 2nd DAC. Then I would program the 1st output to be x/256, and I wouldn't need a Divider for the OpAmp input. The 2nd DAC would directly drive the OpAmp.
Posted: Sat Jan 19, 2013 12:00 pm
by danlee58
I have run into a problem. The I2C bus outputs are on PO(2), and PO(3). These are not available on the PRO or ARMmite boards.
The DAC that I have on order rquires SDA & SCL for the I2C data transfer.
Posted: Sat Jan 19, 2013 1:35 pm
If you stick with the 2103 on the PRO, then use the bit banged I2C
Posted: Sat Jan 19, 2013 2:55 pm
by Pompey2
danlee58 wrote:I have run into a problem. The I2C bus outputs are on PO(2), and PO(3). These are not available on the PRO or ARMmite boards.
The DAC that I have on order requires SDA & SCL for the I2C data transfer.
Access to the I2C lines IS provided on the PRO. The 2 lines are brought out as P17 and P18 on J6 - just above the LED on the right side of the board.
http://www.coridium.us/files/Schematics/ARMproSCH.pdf
I've installed 2x4 headers on all my PROs for easy access to SDA,SCL,Gnd and V3.3.
Hardware implementation is much more reliable, and smaller code, than bit banging.
Chris
Posted: Sun Jan 20, 2013 10:55 am
by danlee58
Chris,
Thanks!
I'll jumper P!(17) & P1(18) to IO(12) & IO(13). They are unused and will be tri-state. This way they will be available on the Prototype Shield thriugh the Header.
