DataLogger-IO-8.37-Spreadsheet
mikechris
Post by mikechris »
Attached is an Excel-97 spreadsheet (and a PDF version) that defines the pins on most of the connectors
on the DataLogger, a good place to start for any DataLogger project, includes both old and new connector
numbers. Spreadsheet shows which IO require Firmware 8.37 to work correctly. See also "DataLogger-IO-Issue".
DataLogger-IO-8.37.xls
(39.5 KiB) Downloaded 2316 times
DataLogger-IO-8.37.pdf
(179.88 KiB) Downloaded 2390 times
TodWulff
Re: DataLogger-IO-8.37-Spreadsheet
Post by TodWulff »
Thanks for the resources. Much appreciated.
